Guys, lets take a minute here and view all the facts.
Ok, I've now had my iphone 4 for the last couple of weeks (which is the best one yet I may add) and I think it's now time to put my views out on the issue of the "problems with the antenna".
I have noticed, and I must say that I had the same issues with the 3gs is that the phone seems to have trouble with 3g reception, but if you turn that off and rely on Edge I have no problems at all, no dropped calls, brilliant call quality etc, no matter what way I hold the phone (I'm left handed and would rather hold the phone with my right hand).
So it comes down to this simple question, is it a hardware fault or is it down to poor provider 3g service? If it's the latter which I think it is, then we need to start getting on the backs of whatever provider you use. I'm from the UK and with O2 and where I live I know that 3g service is borderline crap, so that's why I stick to edge for making calls.
If what Apple says about the signal not being displayed properly and after the fix it shows the true signal is worse that you first thought then it really is down to the provider to sort out their service.
I know some of you will say, why turn off 3g and make web browsing slower, but really, you're not going to do that as often as making calls, and besides, we hold the phone differently when browsing so if 3g is on, the phone will still be able to get 3g data speeds. So all I can advise is, if you're gonna make calls, make sure 3g is off (unless you're in a really strong signal area), and only have it on for web, face book access etc until such times as the providers sort out their now apparent poor 3g service.
Besides the battery will last so much longer if 3g is off until you really need it when you're out and about.
