Hi there!
My iPhone got water damaged. I dropped it in the toilet but recoverd it in less than 5 seconds.
I tried shutting it down but it would keep turning back on by itself. Also, the LED light was on and I could not get it to go off even with the flashlight option turned on and off. I put it in a container of rice and I was finally able to shut it down. The light still wouldn't go off. I tried smashing it ''softly'' and it did turn it off so I thought I just had to leave it in the rice for 24 hours now that it was turned off and that the light was out. But, the light turned back on I can see it through the rice even though the device is off. Sometimes it goes out for 1-2 seconds, blinks and even dims a bit but it's strong enough that I can see it through the rice.
What should I do now ?
Thanks in advance!​
Thanks in advance!​
