Hello - searched the site for a while, and did not find any solution to the problem I created.
Long story short, I did the bad thing:
-I4
-Jail Broke w/ Green poison around Mid Feb 2011
-Today I hit the "Settings/General/Reset/Erase All Content and Settings" about 0.25 seconds before I saw the "Do not do this if your phone is Jail Broken" disclaimer
Now phone loads, shows Green Poison Icon with spinning-load symbol, then hangs at Green Poison Icon, then eventually reboots itself to start the cycle over again.
Tried Itunes restore - no success. It appears to complete, but then goes back to the hang at boot cycle.
Tried re-running Green Poison, it completes through the process with white text scrolling and all, but then goes back to the hang at boot cycle.
I did see posts on TinyUmbrella, but not sure if that would help and wanted some advice before messing it up further.
Any ideas greatly appreciated!
Thank you.
-I4
Thank you.
