Dropped Iphone in water and still sort of working.
Donald8274
Hello, I recently obtained an Iphone my cousin had dropped in the sink. He bought a new one and gave me this one because he didn't think it would work anymore. I plugged it in and it turns on and is functional, however, sometimes it will go to a blank white screen and the power turns off even when it's plugged in after a certain amount of time. Also, he jailbroke it so I can't take it to a place to get it fixed because it voids the warranty. Is there anything I can do to make the battery actually charge and make the screen not turn white? Thanks for any replies.
Darkstar2007
Administrator
On a Lake in Alabama
Try putting it in a bag of rice for two days. That should draw the water out. The warranty doesn't cover water damage.
OP
D
Donald8274
Do you think that would work? It's been sitting around in his room for about a month or two.
Darkstar2007
Administrator
Oh wow in that case probably not! You can try it anyways. Nothing to lose right? Lol. If it works you should let us know! It'd make a good story lol :)!
OP
D
Donald8274
Ok, thanks for the support =D. I'll try it but I don't think it will work. I might just have to either get it fixed or buy a brand new iphone.
Darkstar2007
Administrator
No problem! That's probably for the best. Good luck!
