- Oct 19, 2011
Ever since jb I have horrid battery life. Are there any known apps, tweaks, or themes that place high draw on battery?
Anything annimated like a video wallpaper... or something that constantly requires connection to your wireless data will put a heavy load on your battery usage.....high draw on battery?
way2fast4u said:OP i was having this same issue and what i did was recycle the battery .. Since jailbreaking i got 3/4 of the day with moderate text and emails and calls now that ive let the battery completly die then charge it back up.. now my battery life is a 1 1/2 days..
MikeCorruption said:Do you close your apps after you have finished with them?
If not then just double tap the Home button and youll see those apps that are opento close them just hold one of the apps (like you would when you want to delete an app off your springboard) and when they start to shake just click cross
done
really? but surely if they are kept open then they would drain the battery?That only helps to conserve RAM.....not battery.....but it is a common misconception on the iPhone.
MikeCorruption said:really? but surely if they are kept open then they would drain the battery?
i am not doubting you, but i am really curious how you know thisOnly apps that run in the background can potentially drain battery. But 99% of app cannot run in the background, they are only paused in RAM. Multitasking in iOS is basically nothing like it seems.
MikeCorruption said:i am not doubting you, but i am really curious how you know thisim always keen to extend my knowledge.
