Was wondering if anybody has tried charging their iphone 6 with a 3rd party charging cable
It will work but it not efficient as the genuine apple ones.Was wondering if anybody has tried charging their iphone 6 with a 3rd party charging cable
There's a chip built into the Lightning connector in an Apple charging cable. It's this chip that's used to authenticate genuine cables.I bought some $1.00 lightning cables at the flea market. These cables will charge the iphone, but not an iPad Air. These cheap lightning cables for some reason charge the iPhone very slow - at least twice the time vs. using the factory cable.
I then tried some amazon basics lightning cables, which charge the iPhone at the same speed as the OEM cable, and also charges the iPad Air.
I'm still trying to figure how the iPhone is detecting OEM cables and aftermarket cables. I know other cables for various other electronics use a Dallas one-wire IC to validate the cable. Makes me wonder how apple is doing this.
I'm using the Apple cable that came with the new iPhone 6. It works fine plugged into the charger, but fails with the unsupported accessory error every time I plug it into my computer's USB port. I've tried different different USB ports and multiple computers, and they all do the same thing...It still sync's but will not charge.
I'm also seeing corrupted songs every time I sync. (you can tell because they are greyed out in iTunes). I have to delete all the songs off my phone, then re-sync again to fix it. Pretty annoying. Never had this problem with my i5 on iOS 7.x
As for 3rd party cables, it's the exact same thing. Charges fine plugged into power, but fails every time plugged into the computer.
Have you tried the charging cord with any other iPhone or iPad? If it works with them it would support the theory that the problem is with your iPhone, not with the cord or the computers. If you don't have another device to test it with, you could try it with a friends iPhone or iPad.Have you taken it in to an Apple store @Voidths. Sounds like it might be an issue with the phone, if an apple cable is causing the same issue. I would be interested to hear how you resolve the problem, if you are able to.
