wifi help
blindb9
Just wondering if there is a way to connect to my home wifi on my iphone4 without having to type in the password? is there i way i can make my router "trust" my iphone? i have a linksys wrt160n.
thanks in advance>>>
DannyBoy
Lubbock, TX
Sounds like you need to log into your router and set your phone as one of your devices.
Oskie
I had to put in the password for my wifi on the first attempt only. Since then as soon as I get within range of it with my phone it changes from 3G to wifi automatically.
krist8
The great white north
How do I find out if my connection to internet is through 3G or wifi (wireless network at home)?
I hate to give ISP's more money if I can avoid it. So, if there are wifi hot spots, how do I ensure I am accessing internet with wifi and not 3G?
Tx
5er driver
Germany
Disable 3G and enable wifi. The wifi symbol will appear next to the signal strength bars/carrier name in the upper left corner of your screen.
