- Jun 16, 2012
Hey, at first i promise that i will change myself completely, and now for the important part, after i have installed Springtomize 2 for iOS 5.1.1, and put Cover flow, and create folders in dock enabled, and i have infinidock, too, okay so the problem is that when i open a folder in the dock, then close it, this happens
And after i scroll to the left or to the right( in the dock ) the files and everything in the dock returns to normal. Any suggestions?
Edit: Plus: i wont lose infinidock to remove it, its not really annoying because it disappears when i scroll in infinidock, but it would be better if it gets removed.
