Jailbroken iPhone4 running 5.0.1 resprings on every other incoming call
Kelz
Hello all,
I am not sure if there is already a thread for this problem, but I have a tethered jailbroken 5.0.1 iPhone4. Recently, I notice that my phone resprings on every other incoming call. I am not sure what is causing it and hope that someone can help me figure this out. I have tried deleting the most recent cydia apps but to no avail.
Thanks in advance for your help,
Kelz
Well, you've definitely installed something which is not 5.x compatible on your phone. List what tweaks you have installed and we'll see if we can spot the culprit for you..., but it's likely to be something that tweaks the phone app!
One of our moderators was having this same issue and we determined that it was because she had both CallBar and AnyRing installed simultaneously and they are not compatible together. If the respring happens when receiving a call it is most likely because of a tweak that modifies the phone app in some way(ringtones, callbar, etc).
Thanks for the reply. Here is a list of all the tweaks I have installed; some were probably installed with Cydia:
ATL slider
Activator
Anyring
Apt 0.7 https meth... (probably came with cydia)
Barrel 2
bigboss icon set
bob marley (lock screen)
bob marley black and white (lock screen)
bob marley theme (from zodttd & macciti)
bob marley theme (from bigboss)
bug fix: duplicate
bug fix: stuck pages
clock hid-pk
color keyboard
custom
cydelete
cydia installer and translations (both probably came with cydia)
Dreamboard ( I have two not sure why or how. one from insanelyi and one from modmyi)
fake carrier (from bigboss)
five icon dock
folder enhancer (mesh background)
folder enhancer
fontswap starter
gui-gpg-sec
iglasssol original
intellishared
intellistatusbaric...
izippersliders
labelslider
marley battery
mj rip wallpaper
mobile substrate
n6 HD
red weed slider
repo icons
shelf
slide to unlock killer
slide to unlock text color
slider zipper
substrate safe mode
tetherme
tetherme apn edit
truprint
winterboard
wooden folders
wraparound
xsellize security
3g unretrictor
266 hd icons
I know that's a lot... I have already deleted some but I still have the problem.
Thanks again,
Kelz
Thank you guys, I deleted both anyring and callbar and it appears I no longer have the problem. I really like anyring so I am going to try reinstalling it. I hope it works....
Kelz
Thanks, I now have only anyring and like you said it did not work. I will delete anyring, reinstall callbar and as you recommend, wait until there is a fix.
Thanks,
Kelz
