Ifile help?
Ifile help?
Branson_f
I've downloads ifile and I am want to delete some of the mandatory apps. What is the process in doing this?
You do not delete apps through iFile, just hold your finger down on the app icon until your springboard goes into "wiggle mode" and then press the red "x" on the app you want to remove.
Alternatively you can uncheck or delete the app in iTunes and sync your device.
