help me
ali2ndyear
hi guys i am using IPHONE 3g(jailbroken) i want to improve my camera result.
how can i improve my camera result????:camera:
Well you did not mention what kind of improvement you are looking for, what kind of photographs do you need, and also what size. Obviously, the camera in iphones is not designed to replace genuine powerful cameras. However, I would advise you to improve your images with the help of some software.
Try "HDR" (High Dynamic Range) enabler. HDR is also available in Springtomize 2's "Capabilities" section. Just make sure to enable everything you use.
i want to improve camera pixels and quality also i am new user of iphone
Really nothing you can do about that. Unless your jailbroken. And even then us cant improve the pixels.
Well you can use different software's for this, you also can search for software's on Google. And in your iPhone go in camera setting and make changes which you like for good quality image.
jamesfrenkline - no software will help. It can make pictures only more colorful or brighter, but it won't improve quality. Hardware (camera) is what it is - there ir no option to "upgrade" it :)
