won't power on when remove AC adapter.
ifonelover
Hello all,
I have 3GS-16GB. It has problem with the power on. If I plug in the AC adapter and it turn on. If I removed the AC adapter. then it won't turn on.
Any info . I appreciate a lot.
Regards
IfoneLover
Circuit issue inside the iPhone? Or battery is dead? Take it to Apple store.
Hey Bab2010..
Too expensive to go to Apple store. Do you think I can open it and check any lose cable that connect to the battery?
Is it easy to open?
ifonelover said:
Hey Bab2010..
Is it easy to open?
There is a lot of videos on YouTube and websites dedicated to demonstrating repairs on iPhones. Ifixit.com is a good site for repair manuals/videos and ordering genuine replacement parts.
Thanks! DarkStar2007.
I will go there do some more research.
Regards
I opened it and found out the battery ribbon cable was broken. I replaced it with new battery and it work.
Thanks guy.
