ihi all hope someone can help i have a iphone 3gs on 5.1.1 on vodaphone it was jailbroke with bb 6.15 ipad baseband and ultasnow installed i have just done a restore using itunes all went well untill i got to the settings point ie select country did that put my wifi password in then went to the bit that says activiting iphone but it just fails to activate i have no service in the top lefthand corner off the phone and it also has the wifi icon so i am conected to the wifi just will not active and in itunes it says there is no sim in the ipnine you are trying to install
thanks inadvance kind regards
