iPhone 4s sound problem? Help
chillenandy321
Orlando, Florida
The left side volume toggle buttons for raising and lowering ringer and alerts is not working anymore. Only way to control the ringer and alerts is from inside the settings itself. What to do? iPhone 4s 5.0.1 jailbroke
You do have the "Change with buttons" option in Settings > Sounds set to ON don't you?
My iPhone 4 used to do that, hasnt happened on my 4s. The cause was dirt in the charge unit, the phone thought an
accessory was attached. Cleaned it with a toothbrush and it worked again.
Random and might not relate to your problem. Give the restore a go.
