Help!!!
Help!!!
Silversting80
I recently made a foolish mistake when restoring my device. I said yes to the 4.2.9 upgrade :(... Now I don't know how to downgrade to the 4.2.8 that I had. Unfortunately I don't have a SSH Blob saved either.... Please Help!!!
If you are sure that you don't have any SHSH Blobs saved then I'm afraid you are out of luck. There is no way to bypass using them (hence why you need saved copies) to downgrade your firmware. You are stuck at 4.2.9 for the time being.
You can still jailbreak 4.2.9 using the latest redsn0w beta, however it is a tethered jailbreak.
Well I guess I'm SOL then.. Thank you for your help.. Keep me posted if you see an update.
