- May 13, 2014
Hi everyone! I have my iphone set up almost perfectly to my liking, but there are a couple system apps that I wish I could tweak a little. I've been able to accommodate almost everything that android has and ios doesn't accept these two. I like how when you set your alarm on android it tells you how long from now the alarm time is. Just like to know how much sleep I'm going to get without thinking about it. Also, I like the way the android calculator shows the numbers and you type in a long equation, so that I can look before I hit = to double check that I typed all the numbers correctly. Are there any ways to fix these things on the stock apps? FYI I'm on a 5s ios 7.
Thanks!
Thanks!
