- Nov 7, 2011
Hi does anyone know my wifi is so slow it only loads up to 0.20 Mbps sometimes it goes up higher than that but pretty much all the time it stays at 0.20 Mbps
plz help
Astrix said:How long did you use this router?
- If quite something, look forward for new router.
- Do you do any setting changes to your router recently? If yes, what your last setting.
- Have you try upgrade your router to the lastest firmware? If No, give it an upgrade.
Hope it help and hope someone will pump some input to assist you soon.
Hi my router is netgear wnr2200 I've had it for a year do u think I need a better broadband plan or something ?
