Water damage
Water damage
Dooooooo not do that nail polish contains acetone witch melts plastics and disolves glues. I recommend isopropyl alcohol with at lest 90% but higher is better. Then if you have he aptitude take the system apart and remove the screen battery and speakers and soak the rest in a plastic bin for 1-2 day depending on the serveruty Of the damage. If you do not romove the parts make sure to know this. The battery needs to be drained or it may cause a fire and the screen will look like it has water behind it that will go away over time and is harmless
