Pictures Rotation Problem
mbworldz
Hello, all in a sudden I am not able to rotate the pictures and videos from album. I notice that there is a lock on the upper right, but I can't recall how I enable and disable it. Does anyone know how to fix it ?
Double click the home button to reveal the multitask bar, scroll to the left inside the multitask bar, you will see that icon there, touch it to desable rotation, touch it again to enable rotation whenever you want your screen to rotate again. Press home button once to close multitask bar.
wow thanks. That did the trick.
You are welcome. What's the name of the theme you are using?
It looks good, i will install it and see the out put on my device. Thanks
U may like it. The only reason I installed it is the lockscreen. Its clean and simple.
Yes, it's simple and i like it. Thanks for sharing the name.
