Yesterday i plug in my ip4 with a speaker to litsen to the music then after i plug off a few hour layta i relize that no sound (massage,lock,ipod) . I try to restart and nothing happen .but when i plug it back to earphone or speaker the sound is avalaible. Anyone help me
Connect it to your computer and lunch itunes. Leave it connected to itunes about 10mn, then disconnect the phone and then restart it and try playing a song to see if the sound will come out.
You can also try to blow air in the earphone socket see if it helps.
If the issue keeps on happening again and again after connecting it to itunes, """"right after disconnecting the phone from your computer""" perform a soft reset. This should restore some missing or defective files into the iOS, infact you are having corrupted files in the system. Just Connecting to itunes helps some times, if not soft restore should help, else then a complete restore.
My iphone 4 doesnt make any lock sounds.When i try to lock it it ... Hi, Hold the phone face on and have a look on the side at the little..microphone mesh, or top microphone are used...
