iphone 4 battery connector problem........
r1passedu
I was replacing the battery on my iphone 4 and when I went to pop off the connector, the plug came off the motherboard itself. Has anyone tried to fix this before or anyone know of any videos I can see so I can fix it. also heard of wire glue, maybe that might work, but I just wanted to hear what other people are saying firsy before I try it. Any help would be great, thanks.
What do you mean by the plug came off the motherboard?
Sent from my iPhone 4s using iPF.net
the battery has a connector that plugs into a socket thats welded to the motherboard. the socket came off the motherboard...
