So yesterday I was trying to jailbreak my iphone 3g which did not have a functioning sleep button. I found a way to put it in dfu mode on a forum, and it worked. I proceeded to put it in PWNed DFU mode, and I went on itunes to install a custom firmware. During the installation, the restore froze (for a long time). So I clicked the "X" at the top right of itunes and exited it. Itunes gave me a message saying, "You are quitting your restore; you will have to restore your device later" or something along those lines. Now for the last day and a half, the iphone isn't recognized when I plug it into any computer, and the screen is black no matter how much I try to hit the home button. (Sleep button is broken) What are my options? I am an experienced jailbreaker, but I have never done it on a device without the sleep button. If it had a sleep button, then I would hold both buttons, but I obviously can't do that. And fixing the sleep button isn't an option; the previous owner ripped the ribbon connector straight out of the motherboard. Any help would be appreciated! Thanks!
