Help my cydia has gone empty?
Check your repos. See if they are all still there. If not you can add them all back in. Don't understand why they would be deleted though. Have you installed anything recently...?
Nooo no sources no pacckages no changes nothing is there?
i installed nothing???
Strange. I have no idea why it should have done that.
You've only really got to options. Either find a list of defauld reops and add them back in one by one or rejailbreak and install cydia again...
and i bet all your SHSH dont show also right? it happened to me last week, just wait it out and go to changes every now and then and press refresh, itll come back sooner or later, same thing happened to me man, no worries
nope, i made a thread about this before also, no luck there either, also mine disappeared again...ugh
I remember after restoring to 4.1 cydia got installed without any repos except the Ultrasnow one. I restored and jailbroke again only to get the same result.
I found this fix. Go to /var/mobile/Library/Caches on the phone and delete the ‘com.apple.mobile.installation.plist’ file. Then reboot. Unfortunately that didn't work so I restored an jailbroke again and all was well.
Although this was on 4.1 with greenpoision on the old cydia it may be worth a try...
