Cydia problems
Cydia problems
Darkadam
Bournemouth
Hi, so I have 2 problems with cydia - firstly, I can't install any new cydia apps as I get errors (look in images) $ImageUploadedByTapatalk 21368257819.973212.webp$ImageUploadedByTapatalk 21368257834.231527.webp$ImageUploadedByTapatalk 21368257851.975047.webp and anything I try to install/uninstall, it always tries to install lib zip as in the image. Any help?
Thanks
Remove all additional repos that you have installed. Then restart you phone. Then again add all the repos. You can install apps now.
This worked for me.
