Cydia is really small how do you fix it?
Tbangert
Cydia starts small in the left hand top corner how do you fix it?
This is usually due to an incompatible tweak, try uninstalling whatever you installed immediately before this error started happening.
How do you uninstall the tweak when it so small?
Just to throw it out there, almost all Cydia problems can be solved in safe mode, including the case where your device is stuck on the Apple logo, but you can still hear the sound that your device is connected to your PC and does not come up as in recovery mode, or you can hear the screen capture sound. That's why SBSettings is a definite must have since by default, it'll install safe mode for you
