Cydia help !
Cydia help !
ezone
I've been trying to uninstall dreamboard and other tweaks from Cydia but everytime I try to remove/uninstall it says "http/1.1 403 forbidden" any help will be greatfully appreciated
I'm guessing you're getting the 403 error when it is trying to update the repos from the sites.
So when you are in Cydia, and you browse to dreamboard and press Modify, then Uninstall, what happens exactly?
When I try to uninstall dreamboard or any other app it Immediately says it
I've removed all my repo's and still have the same problem. I don't want to restore. Help
bab2010 said:
Are u on 3g or on wifi? Sometimes this is related to connection speed.
Ive tried on both and still the same error shows up
i assume that you have already tried all possible ways to fix it without having any good result. Well i think you only choice here is to perform the jailbreaking again, or restore the iOS and then jailbreak it.
I really don't know what I did. All I remember was that u reboot my phone and worked fine after that.
I got the error again this time it was a bad repo I removed the repo and the error went away
