Battery Case problems
bkosonen
Hey guys, I picked up a Battery case off Ebay for my Iphone, when I turn it on, it will make the sound like when you plug it in to charge it, then it will sound like you took it off the charger, and it will do that sometimes and turn on and off. Its really weird. Any one have any problems?
Is it an official supported case ? Or a cheap china knock off ? Because those can cause problems.
Not sure. I'm sure it's the cheaper one. But it has the on off switch. Do you guys know if you can charge both at the same time?
I too bought the cheap one from ebay, it was working ok until the micro usb port broke and went in, it was money wasted. I then bought the more expensive one the morphie juice and it is money well spent and I am fully happy with it.
