Audio
Audio
mcaldrick90
Hey guys just gone to use my I phone 4 today and I'm not getting any sound. Made sure it's off mute an it rings ok. But not getting any sound otherwise unless my earphones are in :( can anybody help please.
elitegamer767 said:
Have you tried a restore via iTunes?
Sent from my  iPhone 4S using Tapatalk ☠
Yes I have still no luck. It's as if it's stuck in headphones mode. Will I have to take it to apple shop or is there anything else I can do?
Yes I have and still no luck :( its as if it's stuck in headphones mode. Will I have to take it to apple or have you got any other suggestions?
I have also had this issue on a daily bases. I took my iPhone 4 into an Apple store and they cleaned the connection port out & so far no more problems so it might be worth a try.
Hey Guys I have this problem my iphone 4 iso 5.0.1 thats not loud enough while playing any type of sound (ring, Ipod music, web) I made sure the speaker is clean but no luck,my brothers iphones are much louder. any ideals?
