Does it only show up when sbsettings is installed? And you said that you never themed BEfore sbsettings.
yeap never themed iphone before..and once sbsettings is removed that thing is removed too
The solution is very simple... clearly u've installed Activator since u can access sbSetting toggle from the top bar.. here are the steps to disable them:
1) slide the top bar to the right, left or downward in order to get the sbSetting menu
2) go to more
3) Activation Methods
4) scroll down to status bar: uncheck the swipe down,left or right or whatever u've got.
hope that'll help
i dont want to disable that..look at the first page at my screenshots then you'll get what i mean mate..thanks anyway
