Hi, I got a bad problem on my hands and was wondering if anyone could help me out?
I recently damaged my iPhone 4S (jailbroken, 5.1.1) by getting water in it, and now it won't turn on at all. It wont even show the Apple Icon. However when I plug it into the charger and hold down the power button to turn it on as usual it turns on and I can use like usual but it cant connect to the internet, or my 3G. I want to get the warranty on it all set up so maybe I can get a new one, or get it repaired, but I can't send it in jailbroken.
So Im trying to restore it to factory settings but when I connect it to my computer (PC, Windows 7) all it does is go through this boot loop, and it keeps showing the Apple Icon for a little while and then turning off, and then doing the same thing over and over. It also does that if I plug it into the charger and don't do anything with it for a while. So after giving up on the computer Ive tried restoring directly from the iPhone, but when I try that it just shows the spinning loading circle for a while and then shuts off again, and when I reboot it, nothing has changed. I dont know what else to do? Please help! I could be in big trouble! Thanks.
