IPHONE 5 SUDDEN DEATH and WIFI PROBLEM
GRAFIX
Guys we are now facing some technical issues regarding the sudden death and wifi problem in ip5 and till now we are looking for solutions..The volume of units we are now receiving is getting high.If anybody knows the fixes please share with us..
Thank you..
No power at all..no cause.it's just shut-off permanently.
Thank you..
Welcome I donot understand your concern...what is volume of units you are receiving mean. And sudden death? Please explain
Thank you
Sent from my iPad using Tapatalk HD
Thank you
This member works in some type of technology repair field I believe... thsu the "units receiving" part.
Colin I agree... this "Sudden Death" terminology isn't something we've heard here at iPF. As far as the wifi issues w/ the iPhone 5 goes... it's software related that hopefully iOS 6.1 has fixed for users.
I agree I cannot identify what country the OP is in so it makes it hard to respond. The iPhone 5 is a dream and frankly we have no issues with 6.1 and no issues with wifi plus it seems a better battery life. If users are having problems they should proceed to do a soft reset. Then in addition fully reset the modem/ router.
Colin , administrator down under in Australia
Pardon for the term,we usually term it like that due to no cause or symptom of sudden death as it happened in Samsung S3 (which I believed it is related to SW issue with the kernel).About the wifi technical issue, it has a weak signal.
