- Jul 12, 2010
You just jailbroke your iPhone and you are not receiving MMS and Facetime is not working, well this is what i did to Fix it.. its easy
First open Cydia, and then do they Complete Upgrade that should pop up after it is done it should be required to Reboot then do it, after it Reboots open up Settings and then Phone, turn on Facetime and there you go it should work from there.. if not try a Network Reset also, if not again try to Restore and Re-Jailbreak.
