- Jul 12, 2010
Step 1- Turn 3G off when not using it, To do so go to Settings> General> Network> Enable 3G OFF
Step 2- Turn off Bluetooth when not using it, to do so go to Settings>General>Bluetooth>OFF
Step 3- Turn off wifi if youre not using it, Settings>Wi-Fi>Off.
Step 4- Turn off Push Notifications, Settings>Notifications>Notifications OFF.
Step 5- Auto adjust Brightness, Settings>Brightness>Auto Brightness ON.
Step 6- Turn off vibrate,Flip the Switch on the left side of the phone up.NOT RECOMMENDED IF IN SCHOOL LOL.
Step 7- Turn off Push Email (Settings>Mail, Contacts, Calendars>Fetch New Data>Push OFF.
Step 8- Fetch new data manually (Settings>Mail, Contacts, Calendars>Fetch New Data set to Manually (AT BOTTOM).
Step 9- Shut of Equalizer (EQ IN PHONE), Settings>iPod>EQ>OFF
Step 10- Use Airplane mode when there is no coverage, Settings>Airplane Mode>OFF.
Thats 10 steps to help you save battery life, i use them. it works.. now to drain it, just reverse all that, (LOL).
