The main problem is, my phones battery is dead and the boot loop kills it so it turns on everytime at 4% then the loop brings it back down and it repeats I cant manually turn it on.DFU mode is tricky and you've got to get the timing down. May I suggest you use a timer to get that initial 10 seconds down.
If you cannot get the phone into DFU mode, then you have a hardware problem.
Marilyn
Already triedHallo..Try two hard resets,one after another..It worked for me..[emoji6][emoji6]
It doesn't charge correctly. The boot loop drains the battery faster than the charge. I've tried DFU more than 20 times..So u said it charges? Can u put it in dfu mode while plugged in so its recieving power?
Sent from my iPhone 6 using Tapatalk
Using a jailbreak to change basic things in iOS without understanding the consequences is the main source of jailbreak problems. This usually results in having to restore the phone and losing the jailbreak.Does it hurt to jailbreak the iPhone 6 in any other way than voiding the warranty. Couple of my friends did a jailbreak on their iPhones and they claim it does not hurt the iPhone in any way. Should I believe them???
It's never recommended to use the erase all content and settings. In almost every case it causes problems such as boot looping that can only be resolved by connecting to iTunes and using DFU mode to restore the iPhone.What jailbreak method did u use? I did this once on a 5s pangu jailbreak (reset settings erase content) but never caused such a boot loop although it did give me quite a bit of trouble trying to get restored via iTunes
