I did a complete restore from backup a few days ago to see if it would improve my battery life (which surprisingly it did!) and everything seemed fine. Much better battery usage than previously. However, when I go into general>settings>usage my time since last full charge stats are blank. I've noticed this over the past two days, restore was about 5 days ago.
It says it will give stats after the next full charge, but that didn't work. When I had it plugged in this morning it said 0 hours of usage, 0 hours of standby which is obviously correct. However, as soon as I unplugged the charger the stats turned to - (blank).
New iPhone 4s (about 2 weeks old), running 5.0.1 and therefore not modded in any way. I've been using the OEM Apple charger- plugged into an outlet, not a USB port.
Any ideas what's going on? Will gladly provide any additional info that I might have left out if it will help in any way.
Thanks!
Thanks!
