My iPhone 3gs has become water damaged. I have dried it out using the usual methods. It tries to reload the software via iTunes but stalls at fault 29 when the firmware is being installed/verified. It then goes into the re-boot loop. Have tried iRecovery to cure the problem but get this message on terminal ;
Last login: Thu Nov 17 16:07:01 on ttys000
iMac-:~ GaryBaker$ /Users/GaryBaker/Desktop/iRecovery -s
iRecovery - Recovery Utility
by westbaer
Thanks to pod2g, tom3q, planetbeing and geohot.
[NAND] Found Chip ID 98 E7 94 32 76 55 on FMI0:CE0
[NAND] Found Chip ID 98 E7 94 32 76 55 on FMI1:CE8
:: iBoot for n88ap, Copyright 2011, Apple Inc.
:: BUILD_TAG: iBoot-1219.43.32
:: BUILD_STYLE: RELEASE
:: USB_SERIAL_NUMBER: CPID:8920 CPRV:15 CPFM:03 SCEP:04 BDID:00 ECID:00000217D911A3CD IBFL:03 SRNM:[88130KMFEDG]
[FTL:MSG] Apple NAND Driver (AND) RO
[NAND] h2fmiPrintConfig:421 Cip ID 98 E7 94 32 76 55 on FMI0:CE0
[NAND] h2fmiPrintConfig:421 Chip ID 98 E7 94 32 76 55 on FMI1:CE8
[FTL:MSG] FIL_Init [OK]
[FTL:MSG] BUF_Init [OK]
[FTL:MSG] FPart Init [OK]
read new style signature 0x43313134 (line:389)
[FTL:MSG] VSVFL Register [OK]
[FTL:MSG] VFL Init [OK]
[FTL:MSG] VFL_Open [OK]
[FTL:MSG] YAFTL Register [OK]
[FTL:MSG] FTL_Open [OK]
Boot Failure Count: 0 Panic Fail Count: 0
Entering recovery mode, sarting command prompt
gas gauge SWI line low: issuing reset
gas gauge read timed out
hdqgauge voltage bogus: -1mV
hdqgauge temperature bogus: -1dK
Can anybody please help me in deciphering what all this means.
Gary
by westbaer
Gary
