Not 100% sure it is just down to Siri, or even if this is the best place to put this, but I've had a serch and can't find the answer.
Using Siri, no matter what I ask, I get things like 'ok, I give up, could you try again.
If I use the mike for making notes, sending texts etc. I just get the flashing dots.
I've tried disabling Siri, and powering off, then restoring it, but it still doesn't work. Any ideas on what I can try next.
Thanks in advance.
C
Thanks in advance.
C
