Problems with iphone 4 3G connection after updating to 4.3.1
Sarmiento26
I have been having trouble and inconsistencies with my 3G data connection since I updates to iOS 4.3.1.
Anyone else has the same problem? Any suggestions?
It's important to mention that I already reset network settings and deleted the IPWZ from my computer and redownloaded it to see if the file I first downloaded was corrupted.
Thanks
It might just be your carrier provider issue. Have you tried check with them to see if everything is alright at their end with 3g? As for me i'm on the same firmware with you and i'm facing trouble with my gprs, but it's related with my carrier provider not with my phone.
I am also facing problems with my 3G connection after upgrade my Iphone 4 to iOS 4.3.1. My firmware version is 01.59.00 and my Iphone is correctly Unlocked & Jailbroken. Everything else is working just fine, except for the 3G, although it appears the 3G symbol on top and it shows that is trying to request data when I get in any site over safari or other apps. Before upgrade it always worked fine. My carrier is Claro on Brazil.
