my iphone 4s sent itself into recovery mode and is on the connect to itunes screen, i have tried to restore my phone but it will not due to "error 2001" i have tried solutions i have found on the internet, sadly with no sucess, anyone have any ways to get around the error, or even force it out of recovery mode, thanks
Did you try putting it in DFU mode?
- Plug your device into your computer
- Turn off the device by holding the Sleep/Wake or Power button and swiping it off
- Hold the power button for 3 seconds
- Begin holding the Home button without releasing the Sleep/Power button for 10 seconds
- Release the power button and continue holding the home button until you get a popup from iTunesthat your device is recognized as being in recovery mode.
yes i have any other suggestions? thanks anywayDid you try putting it in DFU mode?
yes i have tried this thanks anyway any other suggestions?Welcome to iPhoneForums, benrab17!
Error 2001 points to a problem with the USB connection.
If you haven't done this yet:
Try different cables to connect your iPhone to the computer, use a different USB port, connect your device to a different computer.
Hope that helps.
It's possible that there's a fault in the docking connector. If you have an Apple Store nearby, make a Genius Bar appointment and have a diagnostic check done.yes i have tried this thanks anyway any other suggestions?
ok thanks i will have a lookI did see a lot of people seem to be having this error the fixes I read said that you need a new battery. Google error 2001 and battery. Maybe that is your problem?
