Help
Help
EpicMunchies
hey alll i have bought an iphone 3g which i have found out its jail broken its orginal settings are o2 but im on orange i would like to restore it to factory settings what can i do?
Connect it to iTunes on your computer and restore it there. Is the iPhone factory locked? If yes, then you will need to JB and unlock after factory restoring it.
hello my problem is i dont want it jailbroken no good apps so i wanna factory reset it but its o2 and im orange so what can i do to use it other the jailbreak it where can i get the phone offficaly unlocked
Best bet would be to call into an o2 shop and ask them what they can do for ya. They may charge you (maximum price of about £20) but if they unlock it for you the phone will then become factory unlocked though and you can use any SIM you like in it.
