help! My number unknown
baifasan
My unlocked 4s, phone number unknown ,somebody will help?
If you tap on the "Unknown" it will allow you to put in the number your provider supplied you with
Sent from my iPhone 4s using Tapatalk
It not allow me to put in my number
have you tried a hard reset on your phone,this will clear any glitches,always worth a try.
I have tried before jailbroke, but it doesn't work. Would it be the mobile telecom carrier's issue? My Provider is china telecom.
it would certainly be worth checking with your carrier to see if they can help.
