Hey!
I own a jailbroken iPhone 3gs.
Anyway, yesterday I dropped it (it was only a small fall) in school and when I picked it up and fiddled with the buttons it wouldn't work, so I thought it was broken. However, about an hour later (I was fiddling with it again) I managed to get it working; it turned out it wasn't lighting up because it was after being turned off by the fall). My power button can be a bit dodgy at times!
Everything went fine then, I had full reception and 3G internet, up until I went home.
I always had low data connection at my house (3G only works in my kitchen!) but reception was never a problem. Yesterday though when I went home, I took my phone out of my pocket to realise that it said "No Service". It then changed for a few seconds to "Searching..." and then back to "No Service". This is happening continuously since! I cannot send texts or anything because it's not connecting to my mobile network! I've had no problems like this before..
Today, I left my house, went down town and I checked my phone again. It worked perfectly, I had 3G and everything! Then when I returned home, the same thing happened - "No Service" and "Searching..."
I am baffled as to why this is happening. I don't understand why it won't connect at my house, but it will when I'm somewhere else?
I have tried turning on and off airplane mode, doing a hard reset and resetting network settings, but nothing is working!
Help would be much appreciated on helping me solve this problem.
Thank you!
Jessica
Thank you!
Jessica
