- Jan 18, 2011
iPhone is getting popular in the world. The iPhone 4, it is a revolutionary mobile designed by Apple. It is completed with many functions such as multitasking, video-call, fast and user-friendly email system, and enhanced security which make it more suitable for any age and occupation of people.
In order to meeting high demand of video-call by users, the iPhone 4 supports FaceTime which is an embedded video calling application which can use either the front or back camera over a Wi-Fi connection to talk with another iPhone 4, the fourth-generation iTouch, or any Mac computer running OSX 10.6 Snow Leopard (Wikipedia). However, the battery operating time of iPhone 4 will be shortened easily once FaceTime or other applications are used.
In order to solve the problem of battery runtime of iPhone 4, hotsalesmart Releases iPhone 4 External Battery Pack. The iPhone 4 External Power Pack is a gadget which has two main features and they are maximizing the iPhone's internal battery and also cover the backside of iPhone 4. Another benefit from iPhone 4 External Power Pack is the sleek Power pack that it can snap inconspicuously onto the back of iPhone 4 and add only few millimeters of thickness.
The iPhone 4 External Power Pack is designed with some specifications:
Weight: 65g
Capacity: 1900mAh
Cell type: Lithium-ion polymer
Dimension: 125x63x17.5(mm)
Output Voltage: 5v
Output current: 500 mA
Cycle life: 500 times
Function & Character:
Enhance iPhone 4 signal
Power switch
Sync to iTunes
Signature:
Standby Time - Up to 230 hours
Talk Time - Up to 6 hours
Internet Use - Up to 5.5 hours on 3G network &
Up to 8 hours on Wi-Fi
Audio Playback - Up to 30 hours
Video Playback - Up to 8 hours
Charge EXternal Battery:
Charging method 1: Computer USB port charge
Charging method 2: Wall adaptor (AC 110-240V, USB outlet) charge
Charge iPhone:
1.slot in iPhone
2.switch on the button on external battery bottom
3.close the roof cover
4.charge and sync iPhone to iTunes thru the external battery by USB cable
Weight: 65g
Capacity: 1900mAh
Output Voltage: 5v
Power switch
Sync to iTunes
Signature:
Charge iPhone:
1.slot in iPhone
