- Sep 5, 2011
This article will tell you how to rip and convert DVD to iMac friendly video files and play the DVD movies on your iMac smoothly.
Maybe you want to rip DVD to iMac because running the DVD-ROM can often damage your iMac--DVD discs can easily get stuck in your iMac. Or maybe you want to transfer DVD files to your iMac and then sync them to your iPhone, iPad, iPod, etc.? No matter why you want to convert DVD to iMac, this is the right place for you to find the solution.
To rip DVD movies to your iMac hard drive, you'll need the help of a third-party DVD ripping software compatible with iMac. Pavtube DVD Ripper for Mac (compatible with Lion and Mountain Lion) is highly recommended to convert both homemade and commercial encrypted DVD movies to iMac friendly MP4, MOV, M4V, and an array of other popular video formats. Now just download the DVD Ripper for iMac and follow the steps to copy DVD movies to iMac effortlessly.
Download free trial of the iMac DVD Ripper:
Get 30% Off Christmas Coupon Code for Pavtube DVD Ripper for Windows
Get 30% Off Christmas Coupon Code for Pavtube DVD Ripper for Mac
How to convert DVD to iMac, iPhone, iPad, iPod, etc.
Step 1: Load DVD files
Launch best DVD ripper for iMac and insert the DVD disc into your Mac. Then drag the disc icon from your desktop to the item bar to load the DVD movies. Alternatively, you can click File > Load from disc to locate and add the DVD movies you want to convert.
Step 2: Choose output format
Click the Format bar to choose your preferred video format. As you can see, almost all popular video formats are supported. If you like, you can press the "Setting" button right beside the Format column to change the video resolution, bit rate, frame rate and so on.
If you want to play the output video files on your iPhone, iPad, iPod, etc., you can just choose the corresponding device as the output format to generate videos with optimized settings for a certain device.
Step 3: Start ripping DVD to iMac
Click the "Cpmvert" button on the main interface and the app will start the DVD to iMac conversion. When the conversion finishes, the folder that stores the converted video files will open automatically. You can then play the movies on your iMac with iTunes, QuickTime, etc. smoothly.
