DashboardX Setting Help
hiranuk
Hi
I have installed Dashboardx. How can i move my apps to another page so the Dashboard widget does not overlap the apps. YOu can see on hte image attached that the DashboardX widget SBSettings is overlapping an app "Fedex Mobile". Is there a setting that im missing?
If you have Gridlock installed you can move the widget to a blank page with no icons. Here's what mine looks like with Music Player widget on it's own page:
A addition to dashboard x that I like is homespringwigdet. It makes the first page of your springboard blank so I use it for all my important widgets.
Gridlock will allow you to do this as well except you can choose whichever page you want to make blank. I highly recommend it for anyone who wants full control over icon placement, as you are not limited to what row, column or page you place the icons on.
