- Feb 4, 2015
If i let my iphone6 run out of battery completely, when I plug it it and turn the charge on it can take 30 mins for it to be ready for use again. Is this a known fault?
It's not a known fault, that's the way it's supposed to work. If you run the battery down until the phone shuts off, it can take a while for the battery to charge enough to power the phone. what you describe is perfectly normal behaviour.If i let my iphone6 run out of battery completely, when I plug it it and turn the charge on it can take 30 mins for it to be ready for use again. Is this a known fault?
Agreed, not all computers have the high power USB sockets installed on most newer computers.I wonder how the OP is charging his phone? If charging from a computer it might take longer than charging from the mains.
What you have done is purposely harmed your phone's battery life long term by doing so many full charge cycles. Some suggest doing it once to calibrate but the ideal use of the battery is to charge it between 40-60%. if you go to the Apple site and read the section on battery maintenance you will see that you were given good information. The fault is not in the phone but in your use.Thanks for your reply but do you have any proof that this is intentional? Seems odd.
When I first bought my iphone6 I let it run completely out of battery for the first 10 times and I'm pretty sure it didnt take over 30 mins to become useable.
Anyway, whether it is correct or not, it is poor!
Your battery percentage indicator just needs re-calibrating. It can be done by running the battery down then fully recharging it.Question about battery...just last night my 6 turned off and restart on its own while in charge and now will only charge to 99% no big deal I don't like the % on but just wondering why and how to resolve this ?
