Anyone using Power Bank with Lighting Port
feihu989
Don't want to take an extra micro-usb cable when going out, someone could suggest me a power bank with lighting port input?
I've not seen any power bank with lightning input to charge it. That doesn't mean such a device doesn't exist, I've not seen one.
An option is to get a power bank with micro USB (so you can charge it up). Then use that same micro USB cable with a micro USB to lightning adapter. This adapter is very very small and doesn't take up any space, but will charge your phone. That's what I do...
Here is the one i get from Amazon, a little bit bulky but the capacity is huge.
http://www.amazon.com/CHOETECH-15600mAh-Portable-Lightning-Efficiency/dp/B 00ZCGLBT6/
You could take a look at the goalzero devices there charging port can connect directly to a any usb adapter
