wifi erorr plase help me ios 6.0,1
Unfortunately, I have no idea what language this is. Perhaps a translation should be in order and post again.
i cant uuse wi-fi cant slide on or off and he grey-locked
Ok.... try a Hard Reset first. Then let us know if it's functioning. Hold your Home & Lock buttons together for approximatly 10 seconds, the screen will go black, then the Apple logo will apear. Released both buttons when the Apple logo appears.
i try hard reset resotre clean restore dfu mode if restore
So... you've even tried restoring via iTunes? Just trying to gather what all you've worked on so far.
no this is not work men plase i need you help+
my friend say this is bug on ios 6.0.1 and 6.1 fix this
So, are you saying that you've updated to 6.0.1 and now your Wifi isn't working? Immediately after updaing to 6.0.1?
