iPhone 8 not charging above 1%
Discussion in 'iPhone 8' started by dragonpro723, Sep 26, 2018.
  1. dragonpro723
    dragonpro723 New Member
    Sep 26, 2018
    3
    Hello. i have searced on the forum without the answers helping me. My problem is I have a iphone 8 with an unoriginal battery. I bought it from soemone as a repair phone. Now it connects to itunes and says its charging on itunes, however on the phpne it only makes the charging sound but no charging icon on the iphone.
    so the iphone is stuck on 1%, I think its the battery. But the previous owner replaced the battery again without results.
    what I have tried:
    Electrical tape on the back of the battery connector
    tried brushing the connection (no alcohol or so kust a toothbrush without anything)
    tried hard reseting iphone and restoring it through dfu mode
    I have also tried different chargers etc. Nothing wrong with my hargers.
    i have 1 thing left to try and that is wireless charging if it works or not. If the wireless charging don’t work its the battery, RIGHT? Also ordered a new battery not apple ofc but oem standards and through a supplier I know with 100% quality guarantee. So my last things to try is wireless charging and new battery.
    cuz the charging port works right? It does make sound and connects to itunes and powers on , just shuts down after a few minutes when using it, and then it can’t be the charging port?
    please help :)
  2. digitalcuriosity
    digitalcuriosity Active Member
    Aug 1, 2015
    162
    73
    28
    With my old iPhone6 i had a problem where the plug from the charger, would not connect without me wiggling it at the iPhones socket.
    soon it just stopped excepting the plug, using another cable nothing changed.
    Problem was socket on the iPhone, since it was really an old iPhone6 i just bought a new iPhone8Pluss.
    And today use a wireless Samsung charger.
    But i feel you'r problem is with the battery because it's not a real OEM Apple battery it's not being excepted.
    Are you sure the battery is really that low? Since you can't remove it easily without taking phone apart checking battery is not an east task.
    I wish you good luck is solving the problem.
  3. dragonpro723
    Sep 26, 2018
    3
    Yeah I suspect either battery, or the IC Chip. If it's that one I'll sell it if just battery well lucky then. Waiting for new battery in the mail
  4. dragonpro723
    Sep 26, 2018
    3
    Okay I tried wirelss charging. Gives me same result. Shows charging on lockscreen, but not the charging icon. The phone is stuck on 1% without charging. So since it connects to iTunes and wireless dont charge or charging with cable its the battery then? It cannot be anything else then I think.
  5. digitalcuriosity
    Aug 1, 2015
    162
    73
    28
    I know the feeling that i am losing my phone as i was, and they don't make wireless chargers for the older iPhones.
    This is why today i bought two Sansung wireless chargers, i am not using a plug unless i have to.
    Even today with the older iPhone8Plus your looking at a $700 dollar hit +tax .
    And for some unknown reason Apple made me reset my password, and this is not a simple task trust me Apple wants to be sure it's you and this takes a lot of work.
    Then every program and App you have needs the new password used, and sometimes they won't except the new passwords. Arrrrrr ouch ouch.
  6. 2015Girl
    2015Girl Well-Known Member
    Nov 25, 2014
    627
    633
    93
    P.A. USA
    Can you replace the battery and get an apple battery?
  7. digitalcuriosity
    Aug 1, 2015
    162
    73
    28
    Myself i feel it's always best if you have an Apple product to always let Apple do the repair with their parts, so it just could be getting a real Apple OEM battery it might solve the problem.
  8. scifan57
    scifan57 Super Moderator Staff Member
    Sep 24, 2012
    20,671
    17,996
    113
    Regina, Canada
    How long does the battery last if you disconnect the charger?
    • Like Like x 1
  9. bear7962
    bear7962 Well-Known Member
    Feb 8, 2013
    1,700
    927
    113
    What IOS are you on?
    • Like Like x 1
Share This Page
