Calender entries more than 3 months old disappearing
Discussion in 'iPhone Help' started by True Believer, Mar 16, 2011.
  1. True Believer
    True Believer New Member
    Aug 17, 2010
    8
    I've just noticed that none of my calendar entries prior to January are still there - and even some of those have gone. Does anyone know why this would be?
    I've looked in Settings/Mail, Contacts, Calanders but can't see anything that would enable all my calander entries to be kept.
    Hoping you can help.
    Thanks
  2. True Believer
    Aug 17, 2010
    8
    is this an iTunes problem?
  3. CalifJewls
    CalifJewls New Member
    Feb 4, 2011
    78
    17
    California
    Connect your iPhone to your computer, within iTunes highlight your device in left hand column, click "info" next to summary, scroll down to "sync iCal calendars", you will see a checkbox labeled "do not sync events older than ____days...
    Check or uncheck or choose the amount of days..
    Of course these are directions for Mac/iCal users..
  4. True Believer
    Aug 17, 2010
    8
    Thanks for your help! That fixed it.
Share This Page
